That looks like a good kit there. I like that it has the spindles with it
did you decide to rebuild the rest of the front end now, or going to hit it later on?
Greatly appreciate the feedback and tips.Regarding your rear brakes:
Check the rear flex hose. A few years back i helped a coworker get his 73 340 Dart Sport back on the road. We couldn't get any brake fluid at the front calipers. After disassembling the distribution/safety block and all that I finally discovered that both front brake hoses were blocked. The metal ferrules at the end of the hoses had rusted and completely blocked the internal passages.
In reality, since you are into the hydraulics anyway, you should carefully check the rest of the system before hitting the road. I use synthetic DOT 5 fluid in my 60's cars. It doesn't absorb moisture and doesn't harm paint.
P.S. I have a /6 64 Val convertible too. Fun cars.
if someone doesn't know how old the brake hoses are on one of these, they should always be replaced
Just received notification from Classic Disc Brakes that my order has shipped. Going to pray, burn incense, light a candle, kill a chicken or whatever in hopes that there are no hiccups in the shipping process.
Dam it must be over 3 months since you ordered your Disc's. Yea I'd be a bit pissed especially when you know they didn't ship when promised.
If you check, you will see that this kit bolts right on to existing (10") brake system. I believe that the OP has a 9" brake system.This what I bought for a 71 Demon. small bolt pattern and lets you keep 14" rims. You can buy the kit with power booster or manual. This kit is very complete and comes with a new master which is what you need, expensive but I found it to be a great upgrade.
A153 Front Disc Brake Conversion Kit, Mopar Non Power – SSBC-USA
Nice car!!!
Thanks for this comprehensive thread WV64Signet, I recently bought a 63 Valiant 200 Convertible /6 225, with Drums all around. I've not turned a bolt yet but inspired by your posts I'm looking to follow in your path. My question, did you do any front suspension work during the conversion? Did you end up with Disc/Drum?
