Saw this on Facebook and thought someone may be interested
I’m curious as to what makes the La 360 25 pounds heavier than the other LA blocks.RJSay this on Facebook and thought someone may be interested View attachment 1715822838
Crank and rotating assemblyI’m curious as to what makes the La 360 25 pounds heavier than the other LA blocks.RJ
Wow that much difference.RJCrank and rotating assembly
Sounds about right, it's only 3/4 of a real engineWhy is it so hard for me to believe a slant 6 only weighs 475lbs
FactorySay this on Facebook and thought someone may be interested View attachment 1715822838
And one head instead of 2. Intake is tubes instead of a solid chunk of iron.Sounds about right, it's only 3/4 of a real engine
Do you know what a aluminum 426 hemi head weights vs a iron one?
Big block dart had a write up years ago, it was roughly a 30-35 pound savings per head.Do you know what a aluminum 426 hemi head weights vs a iron one?
You are much smarter than I am so I’ll take your word for it and I’m sure you’ve actually weighed them. It just made so much sense in my head that a cast, externally balanced crank with larger main journals would weigh more.cast crank in 360 wights less than forged 340 carnk......360 pistons are lighter then 340 pistons....
Maybe you've wrestled with trying to stand one upright against the front bed of a truck before? Lol they are awkwardly shaped @475lbs.Why is it so hard for me to believe a slant 6 only weighs 475lbs?
They'll put the hurt on you if you let um. lolMaybe you've wrestled with trying to stand one upright against the front bed of a truck before? Lol they are awkwardly shaped @475lbs.
I watched my brother who's 225lbs struggle and almost hurt himself doing it. Lol thing kept slipping and spinning around and wanting to land on his foot or leg.
I had a 392 back in the day. They were smaller, but darn sure were not lightI can’t help you but I flowed two stock cast iron Hemi heads with different part numbers for a local shop and those dog-gone things were heavy
Philo Beddoe could carry a straight-six without any trouble... can't be much lighter than the leaning tower of powerThey'll put the hurt on you if you let um. lol
I wonder to this day how they faked that. Even an empty block and head together would've been too heavy.Philo Beddoe could carry a straight-six without any trouble... can't be much lighter than the leaning tower of power
