AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 24,913
- Reaction score
- 12,263
With the 262 type cam , I'd be surprised if you couldn't tune 65@2250 into the hi teens/low 20s. That 262 cam will run and make mileage down to 1800 no problem, if you give her the timing she wants.I may have listed the wrong mileage, I'm wanting the gas mileage to be in the low to mid teens
When I read 5mpg, I was pretty sure it was a typo... lol. So I more or less ignored it, but high-lighted it so you could catch it.
Five thousand is a nice budget, and you can build a nice dual-purpose engine for that. Just slam some closed-chamber alloy heads onto it, pump the pressure up to around 185psi, up cam a wee bit, and now you got a tire-frying powerhouse, that still gets hi-teens for hi-way fuel-economy, with 3.23s.
More pressure translates to more low-rpm torque, which translates to a smaller required throttle-opening, at no matter what load the engine is seeing. And that means less rear-gear and especially less stall, is needed.
I had a hi-pressure (185psi) 360 combo back in the early 2000s, with a manual trans mind you. It didn't much care what starter gear it had, and at one point I had it geared down to 3.23 x .71 x .78=1.79 final drive, that on the hiway, turned 65=1450 in double overdrive. But I couldn't give her the timing that she wanted. so I switched to 3.55s, for a final-drive of 1.97 and 65= 1600, and bought/installed a dash-mounted, dial-back, spark-box with a range of 15*. With this and a V-can modded to 22*, I was able to find 48+15= up to 63* of cruise timing; which was just a lil more than she needed. This engine combo made 32mpgs, on point to point hiway cruising, with a Hughes HE2430AL cam, that is ;
270/276/110 and 223/230@.050; in a 68 Barracuda weighing ~3800 with passenger and gear.
That combo was very sweet, but the cam lost lobes right after an oil-change, back when they took the zinc out of the oil and failed to memo me, lol. So the next cam was one size bigger, still a FTH and I got rid of the Mopar overdrive box. But the 3.55s are back in, and still with the GVod. .
The point is; that with the 360HO as a base, lots of things are possible.
Btw
at one point, that 2330 Hughes cam was running on 11.3Scr, tickling 195psi, and still running 87E10, from idle to WOT, at any load-setting.
