TTI HEADERS & MINI STARTER
WAYNE0
milton pa.
I have a 67 barracuda with a 360. I bought the TTI long tube headers & a mini starter. The starter fits fine but its all but touching the tube at the very bottom of the starter. Any of you have that same issue ? What did you do about it ?
I have the OE Dakota mini starter, almost touching, I got a starter heat wrap shield from DEI? Summit carries several sizes. Starter has lasted 2 years so far. Had to modify the wrap a small amount. Have a seamstress?
If it's an actual mini starter, after market, can't you reclock the starter position?
I have a Dakota starter, almost touching, I got a heat wrap shield from DER?. Starter has lasted 2 years so far. Had to .oddly the wrap a small amount. Have a seamstress?
If it's an actual mini starter, can you reclock the starter position.
mmm good question ill have to take a look thanks
I've never seen an OEM mini-starter that's clockable. Aftermarket - yes. There are some different size OEM/mini type starters and there was one style where you have to clearance the block and a little on the starter too. But I've changed my Dart Sport (race car) starter with TTI's without loosening the headers. Does require moving the steering while maneuvering it in & out. Don't recall how close it is to the headers, but it hasn't caused a problem. I might have had 1 starter go out in 20 years on the car.
I have a Dakota mini on my 360/4-speed car with TTIs circa 1999
My mini came with an adapter on it that elevated the terminals to near-touching. I removed that adapter, and then it was fine.
She has not complained at all about the Heat.
In this pic you can see the adapter.
and here it is without it, it just unbolts.
View attachment 1715833135View attachment 1715833134
yes mine has the adapter at the bottom of the starter there is a rubber that covers a nut that is where it is touching its gray in color
