Trim on P side glass
Richie
Kelowna BC Canada
Hi everybody.
Are those trim pieces just glued on?
Here you go Richie,
Order it from DMT. They are awesome to deal with. I ordered this for the same reason, worked perfect!
Search
    • Mopar A B C Body Van Truck Window Frame Glass Setting Tape (2) 36" pcs
(No reviews yet) Write a Review
$7.95
SKU:
GEN6193GT01
Weight:
0.20 LBS
Shipping:
Calculated at Checkout
Current Stock:
Quantity:
DMT 2pcs .045" x 1-1/2" x 36" glass setting tape for all MOPAR applications. This is the "seal" in the bottom channel of the vent window for all 67-93 Mopars with the chrome channel on the bottom edge of the vent window. Also used to hold the chrome trim on on the rear edge of the door glass or the front edge of the quarter glass.
To replace, dig out the old tape. Lay this setting tape over the groove in the chrome channel. Use a mallet to pound the vent window glass into the channel. Trim the excess. See the "how to" link below..
1967 67 1968 68 1969 69 Barracuda
1967 67 1968 68 1969 69 1970 70 1971 71 1972 72 1973 73 1974 74 1975 75 1976 76 Dart, Demon, Duster, Scamp, Valiant
1967 67 1968 68 1969 69 1970 70 Belvedere, Charger, Coronet, Roadrunner, Satellite
1967 67 1968 68 1969 69 1970 70 300, Fury, Monaco, Newport, New Yorker, Polara,
1961 61 1962 62 1963 63 1964 64 1965 65 1966 66 1967 67 1968 68 1969 69 1970 70 1971 71 1972 72 1973 73 1974 74 1975 75 1976 76 1977 77 1978 78 1980 80 A100, A108, D100, D150, D200, D250, Fargo, Sweptline, W100, W150, W200, W250
1971 71 1972 72 1973 73 1974 74 1975 75 1976 76 1977 77 1978 78 1980 80 1981 81 1982 82 1983 83 1984 84 B100, B150, B250
Material(s)
Correct thickness for Mopar applications
Shipping
We combine shipping.
Glass Setting Tape Use - It's not Mopar but it gives you the basic idea of how its used
Here you go Richie,
Search
$7.95
SKU:
GEN6193GT01
Weight:
0.20 LBS
Shipping:
Current Stock:
Quantity:
Material(s)
Shipping
Thank you AAndrews. I'll be using that in the spring. Great tutorial vid too.
