RAMM
I can state that the E Street/RPM casting, in well ported form, without epoxy or welding can support 780+ horsepower using a 451 stroker and 91 octane pump gas.
I do NOT know how you do it Jim, I really don't. J.Rob
How much port work do the Edelbrock heads need to match the trick flows OOTB. I know it's likely cheaper to buy the trick flows for the given flow advantage. But can these E Street be made to flow like trick flow later on? Within reason I guess. Yeah I know define reason right. LOL
I wish the video was still online where the Comp Cams dyno operator during the contest set his readout screen to a maximum of 600 HP.....because......the previous 451 engines had maxed out in the 580's. After our first pull he turned around and exclaimed to the crowd behind him, "IT WENT OFF MY CHART!" And there it was.......a straight line disappearing off into the wild blue yonder with 600 HP down around 5,400 rpm on a 7,000 rpm screen.I do NOT know how you do it Jim, I really don't. J.Rob
