Wouldn't it be nice if they had a flanges running along the top where it meets the floor pans, would look super stock. Make the connector even more ridgid but still allow for some metal to metal flex / movement like origional spot welds do
Those of you guys installing them while on a rotisserie, are you doing the work while the chassis is tipped on its side? If so, any concerns that you’re welding some preload into the structure?
we attached the new roof section that a crack appeared
Yes well my Seam seal has a thin crack in the filler panel seam in front on trunk and between Qtrs..440/500 stroker no cage so I'm getting some twisting.
I am using the Hotchkiss, I like the way they fit and pretty easy to install. 1972 Plymouth Scamp 408ci, 904 trans, 8.75" Sure Grip.
Lol!you won't be sorry, same can't be said about the bank account thou
