Mr. Sinister
Devastation Manager
What cubic inch does it become? I thought it made a 370 but just not sure.
367 at 4.04What cubic inch does it become? I thought it made a 370 but just not sure.
So what about +.030 borehole?367 at 4.04
Thanks it comes out to be 373 C.I. So my guess wasn’t that far off.
10 more cubes and you'll have a Chebby??? small block stoker - 383Thanks it comes out to be 373 C.I. So my guess wasn’t that far off.
Thanks to Moparpuller and RogerRamRod for the answer and info.
Sounds like you own a couple.10 more cubes and you'll have a Chebby??? small block stoker - 383![]()
I bought out a lot of parts and in the lot is a Mopar 3.580 crank with 340 mains and was curious about the cubic inch it would make.Its basically just a .040 over 360, with a bunch more machine work. With the availability of 4" cranks, it doesn't make a lot of sense unless it's just a "want to"
I've had many 350s but never a 383. Down here in S.Texas mopars are a little rare. Chevys are cheap and abundant. The yellow Barracuda in my avatar had to be shipped in from Arizona. I had a Barracuda back in the 70s and always wanted another one so I found the yellow one and bought it.Sounds like you own a couple.
Well, in that case, it would be worthwhile, that way you get the 360 stroke with the smaller mains, better for high RPMI bought out a lot of parts and in the lot is a Mopar 3.580 crank with 340 mains and was curious about the cubic inch it would make.
