Converted an auto center console to a 4 speed version
19cuda67
Jack
Williamston
Here's my auto center console converted to a manual 4 speed version, using tips from a previous FABO how to article.
Looks fantastic! What shifter are you going to use/ do you have to use?
What did you trim the top around the boot with? How did you attach the boot on the bottom? I see the screws. Looks really good
Thanks,
There is a FABO post from years ago that advised you can use a thin body side molding (from a parts store) on the top plate to surround the boot. To be able to screw down the boot, I used deep threaded fasteners that, are held in place with (expensive) two part 3M body structural adhesive.
