trickflow 240 heads rocker shaft offset
tooslow
lockport, Il
hello , looking to buy these heads . I read you have to use the harland sharp offset rocker shaft setup
$2000 plus . Isthis true? Hoping to use my Comp Cam set up off my 906s
Harland Sharp S70015KE - Harland Sharp Heavy-Duty Roller Rockers
These are the 1's TF recommends using.
Summit shows a price of ,$1000 and some change.
Btw I'm using them with my TF 270 heads also
The Comp 1621-16’s will work, but the heads require a little trimming(about .030”) off the inside of the end 2 rocker stands.
Best to mock the rockers up on the heads and take care of this before bolting the heads onto the engine.
Why on God's green EARTH would you use paddle style stock rockers on Trick Flow heads? That's the funniest thing I ever heard of.
Ive had several customers tell me they had some fitment issues with the Comp rockers on the TF heads.
I was going through a set of TF heads for someone, and they were going to use the Comp rockers.
I relayed the info I’d rec’d about where the interference was...... and he decided to have me mock it all up here and take care of any issues.
Indeed, there was some binding of the two end pairs of rockers, just like I had been told.
The end rockers were rubbing on the stands instead of the hold down clamp.
A little trimming of the end stands was all that was required to have it all fit without any binding.
