Thank you. I bought a project with pretty much nothing underneath.No pics currently but it runs up the right side along the inside of the rocker panel and offsets to the left and goes through the front frame crossmember in line with the inside of the front frame rail and then up said frame rail. At the rear it’s pretty much the same and offsets to the inside of the rear frame rail then over to the tank.
Thanks!I can get pics but not until tomorrow night at earliest. I work all weekend.
Thanks!I may have some print photos in a box. The routing is close to '68-9 but I think '67 has slight differences. IFAIK fastback, coupe, and convertabile all are routed the same.
These will get you started.
