I'm ready to start wiring an engine run stand and have a question on the alternator charging circuit. How do I wire the regulator since I'm using just a on/off switch and push button for start? The mopar type key switch and ignition 1, ignition 2 won't be used. Using an old MSD 6AL and blaster coil, so the ballast resistor will be gone too.
