[WANTED] Schumacher A67LA 318 to 360 conversion engine mounts
you can use your mounts with a minor modification to the driver side
I have a couple extra mounts laying around that look different (taller) than some of the 318 stuff. I wonder if they are for a 360. Will stock 360 mounts bolt right into the v* K-member and place the engine in the proper location for the headers etc. to have the best chance of fitting? Would all LA 360 mounts be the same regardless of whether they were in a pas car or a truck?
n
no. they have to be a body
doesn't say out of stock.. or follow the ebay link i posted,
It doesn’t say out of stock when you first go to the item page, but then you have to use the pull down menu to choose the 360 version and that’s when it says out of stock
I connect with Chris at Schumacher. They will have more in stock in a couple weeks.
