Need measurement / distance between front upper shock tower A Body
Joerg
Member
Germany / Hannover
Hi I have bought a projekt car 1968 Formula S, and the guy before has cut out the shock towerns in Front. Can please somebody help me and measure the distances and the drawing I have to weld new ones in and want to make it right ;-)
A = distance between the shock mount holes (midle to midle)
B = distance to firewall, please measure horrizontal
C = distance to front radiator frame
Thank you very much for helping me
I went out and measured for you these are hard to get exact but they are very close. I took these photos straight on as possible I would weld in the shock tower then do the inner fender part as it welds directly to the shock tower.
this is the left side from firewall at the park brake cable hole.
this is the right side from the small recess at the hole for blower motor.
This is the right side from radiator support where radiator bolts.
Left side from radiator support from where radiator bolts.
this is between the shock towers.
cudascott you are today my hero, thank you very much for your help, this will help me a lot
Cheers Jörg
Your most welcome I did edit the wording for the first pic I said speedometer cable hole but it’s in fact the hole for the park brake cable.
"I would weld in the shock tower then do the inner fender part as it welds directly to the shock tower."
The factory only used about 4 or 5 spot welds on the very top of the shock towers and the inner fender. Over the years, my '68 Barracuda convertible had begun to tear those spot welds loose with a slant 6 in the car. When I was installing a complete US Cartool Chassis Stiffening kit, I welded the shock towers fully to the inner fenders.
If you are trying to make it all original, you likely are not interested in altering the car with a chassis stiffening kit. If you are open to building in some improvements, here are some things I found when trying to improve how my car drives and handles for that contingency.
The sub-frame connectors made the single biggest difference in how the chassis felt while driving. The rest of the kit almost eliminated the cowl shake (entire dash and windshield shakes/vibrates left and right at a visible frequency over rougher roads) the car had. With no roof structure, I assume convertibles have more cowl shake than a hard top.
My cowl shake was eliminated entirely after I installed a Monte Carlo bar. At the time, I fitted it for the slant 6 motor and have since installed a 5.9 Magnum based 408" motor with a factory serpentine belt. The bar no longer fit because of the A/C pump, and I have not made a new one. You can see the front frame connecting bar in the picture of the car pulling into Spring Fling in LA a few years ago. US Cartool has since changed their kits to one that is a little nicer than what I have as far as the under radiator frame connector and the under fender bracing.
I'm going to upgrade my engine with a supercharged 5.9 Magnum soon and to handle the added power, my next chassis upgrade will be to tie the front part of the frame rails to the shock towers and through the fire wall under the front fenders to some low door bars to finally tie in the rollbar. I'd also like to run a bar under the dash to connect both sides together.
