siuauto
Hey everyone, I have a 71 duster with tubular upper control arms with the bigger ball joint to accept a disc brake spindle. I have a pin type caliper bracket and 73 duster rotors. The rotor is rubbing on the caliper bracket and the inner pad does not fit in between the rotor and caliper bracket. The conversion was done 10 years ago and it was time to replace the pads so i replaced the rotors due to hot spot marks. Does a 73 A body rotor not work with a pin type caliper bracket? No part number on the old rotor to cross reference but my old set up worked just fine.
