[WANTED] Left exhaust shield 273
65dartcharger
Dart Charger 273 Historian
Tavelsjo, Sweden
I'm looking for an NOS exhaust heat shield for the left exhaust manifold. As you can see in the pictures I have a used one and a McCord set w/Chrysler partnumber. However they are for 318 and 340 from 1967 and up and the left side is different that early style.
Let me know what you have. Thanks FABO.
Looks great. Let me know if you run across another one!
I have only this one and bought it from another member maybe 5 or 6 years ago. As you know I am not married to matching or correct numbers but more or less close appearance or what Chrysler could have done if they had built the sedan delivery
Can't wait to see it finished!❤️
I found a few online out of stock.....and not very cheap. I guess the 340 piece won't work? Ports too big?
318 and 340 don’t use the same one. One has a divider in the center port.
There are four styles
64-68 2465845 - Without the web
65 2465842 - Right - lower portion only, no fans. Best I can tell this was 65 only.
69+ 2946128 - With the web connecting the two sides.
68+ 2946105 - 340 ONLY - ports are different size/shape
I didn't look past 69
Alan
Alan
Thanks Alan. What about 64 and 66, didn't they have that shield without the fans? Or did they have an ordinary gasket?
The simple smaller right side heat shield only was in the 65 parts book. Best I can tell it was the only year that used it.
65 was the only year that listed any number for the right.
Alan
