Just attended the Eve of Destruction at my local race track...I say boost! LOL
BEST ANSWER EVER!
Hi All, I have a 318 in a 1975 Duster with the following specs: 10.3:1 static compression, 4 barrel dual plane air gap intake, Clevite hydraulic flat cam w/226 duration and 0.453 valve lift, headers, edelbrock carb, stock bottom end, some head work I did on my own, and at 5200 ft in elevation. I estimate I have around 320 hp at the crank based on those fun online engine hp calculators. Here's what I want: I want the engine to be more reliable (I have been getting vapor lock in the summer) and I want 400 hp at the wheels and I want to do it in the easiest way possible (not the cheapest) and I do not want to run NOS. I have been looking at Holley's Sniper EFI system along with their hyper spark set-up to increase the reliability. For those extra horses I am considering a Paxton super charger. Again, not cheap (around $10K in total for both EFI and charger) but easier than rebuilding an engine or so I think ha. A few questions I have below:
I'll pay to have the car dynoed and tuned by someone with more experience than me after I get everything installed.
- Is this really stupid? I was thinking I could keep the boost pretty low maybe less than 4 PSI if I opt for a bigger pulley on the charger?
- If I was running 4 PSI of max boost, what octane level would I need for this set-up? I am okay with using 91 and then mixing in something like torco to increase the octane level.
- The Paxton kit requires a hole be made in the oil pan. Does anyone have experience doing this? Curious to hear how you did it? Did it with the oil pan still on the car? Remove the oil pan and drill it?
This engine is not the end goal for the car. I want to build a 360 set up to take on boost in the future (650 hp) but this is maybe 5 years down the line. I am hoping that the supercharger and holley EFI system will be transferable to that new engine. For now I just want the car to be more fun and not worry about breaking down. Not going to be a drag car. Just want to feel some punch driving it around![]()
About 8.5/1 with alloy heads.At that altitude, it’s probably somewhat doable with water/meth injection and boost timing retard. I know of a 318 stroker that was over 9.5:1 with ported Edelbrock heads and cometic head gaskets with head studs. He was pushing 7 pounds at 2,000 feet of altitude, but it was also set up to swill washer fluid at breakneck pace at the first hint of boost.
1971 360 block. Hughes Engines main girdle, bushed lifter bores, bored .030”. Forged K1 crank and forged rods. 228/224 @.050 cam with 114 LSA. Custom forged Diamond Racing pistons. 8.5:1 compression. Hydraulic roller lifters and roller rockers. Hughes ported Edelbrock heads, super Victor intake. 750 Holley blow through carb. 1-7/8” headers, …
Beautiful street manners and it goes like hell.
650hp / 600lbft
My problem was not having the boost referenced timing retard and the water/meth system not being reliable. Right now it is sitting (7-8 years) and needs to be freshened. I have a new Snow water/methanol kit and an MSD 6 Programmable box with MAF sensor to sense boost. New game won’t pan for ignition and boost cooling.
My suggestion to you is to buy the fuel system and set it up and tune it to your current engine. Next, find a new block and start collecting parts for a new short block . You will need a forged rotating assembly, use your heads, use a single plane. Get everything switched over and tune the ECU for boost. Also, if you can fit it use an intercooler. I would but I don’t have room on the front of my E-body ‘cuda.
View attachment 1715964901 View attachment 1715964902 View attachment 1715964903
Impressive numbers. Hey "8.5/1 compression"
650hp / 600lbft
That list is a joke. How can they make such general assumptions and publish it. The only thing I agree with is the part about making sure it doesn’t detonate. The rest is bogus. Example, “8.0:1 is the optimal compression ratio”. Even on methanol? Come on. Another example, “maximum rpm 4500-5000”. The highest load the piston sees is at the torque peak. That’s when cylinder pressure is highest. I don’t know who wrote that but damn.Read up:
Supercharging Basics – Engine Preparation.
Detonation on a stock or worn engine can cause piston damage or burned valves. Most late model "smog" engines work well with a supercharger, due to their lower compression ratios and smaller cam profiles.
Guidelines
If using a stock engine, follow these guidelines for optimization.
- 7.0:1 to 9.0:1 compression ratio. The optimum compression ratio is 8.0:1.
- Higher than 8.0:1 is not necessary or recommended. Fuel, ignition timing, and total boost could become critical factors.
- 4 - 7 psi boost level. This range has proven to be the best compromise for power and reliability.
- 4,500 - 5,000 engine rpm. When using stock cast pistons, the engine should be limited to a maximum of 4,500-5,000 rpm.
- Exceeding this limit may over-stress the cast pistons and cause failure.
- Properly blueprinting an engine will allow higher rpm reliability. It will also maximize a supercharged engine's potential.
- Eliminate detonation (pinging). Detonation is the single most destructive force in a supercharged engine.
- This may include lowering boost level, retarding timing, installing a boost timing master, increasing fuel flow to prevent leanout, and/or using a fuel additive to raise octane level.
- The cooling system should also be in good condition to prevent overheating, which could lead to detonation.
You need to contact Summit and set them straight. They apparently are idiots.That list is a joke. How can they make such general assumptions and publish it. The only thing I agree with is the part about making sure it doesn’t detonate. The rest is bogus. Example, “8.0:1 is the optimal compression ratio”. Even on methanol? Come on. Another example, “maximum rpm 4500-5000”. The highest load the piston sees at the torque peak. That’s when cylinder pressure is highest. I don’t know who wrote that but damn.
NOW THAT I AGREE WITH.You need to contact Summit and set them straight. They apparently are idiots.
I actually do have a pair of 360 heads on the engine. My dad always referred to them as police engine heads but I haven't taken the time to remove the valve cover to check out the casting number. (But now that I am saying I probably will tomorrow) The heads were milled down by like 0.100" to get the chamber volume down. I vaguely remember measuring the volume and it was around 65cc (this was over 10 years ago). The intake had to be milled down to fit as well
I have pretty much zero experience tuning outside of playing with timing a little bit. I would take the car to dyno and to someone with more experience to help out. I was eyeing this company in Denver: Finish Line Automotive & PerformanceMaybe your a better tuner than I am your going to be on the edge
He is. He will be switching to a high pressure fuel system if he goes to sniper or fitech.I might be mistaken here, but I think it would be a good idea to fix the vapor lock issue before introducing more heat into the engine.
I'm not familiar with the FI system's, will this take care of the problem then? Is the fitech system about the easiest one to install and program?He is. He will be switching to a high pressure fuel system if he goes to sniper or fitech.
