Kevin...if you just need 120 volts for a few overhead LED lights and a few plugs on each wall, it wouldn't be hard to run some #12 Romex out to it from your breaker box or power box outside. Dig a ditch about a foot deep and run some PVC pipe with the wire in it. Mount your boxes, run your wire and hook it all up. Then install a new 20 amp breaker made to fit your brand of breaker box and you're in business. It's hard to screw up standard plugs or switches. Black wire goes on the brass screw, white wire goes on the silver screw and nekkid ground wire goes on the green screw. Don't let the nekkid wire touch the brass screw when you push it all in the box after it's connected and there won't be any sparks when you go flip the breaker on...lol. come on man...Mr. White dog needs a little electric space heater in his new house this winter!
