giggitybit
Member
Had built a 5.9l Magnum for a swap, buddy went big block instead.
10:1 hyper pistons
Rings
Clevites (all)
HUGHES Whiplash cam (springs too)
Double roller chain
Melling HV oil pump
Tanked/fluxed/assembled
ARP hardware
Wrapped for the last few years, as I don't have heads for it. So zero mile shortblock (with bad stock heads, intake etc... got a few oil pans (including swap pan) and accessories I suppose.
But what I want - is a decent running 5.9l for my Durango RT... installed.
Basically goes like this... if you have a 5.9l magnum that is good running, totally stock is good and you want to swap it out for a built motor at no cost... install your motor in my durango, you get the cracked head motor from the durango and the built motor.
I'm SW of Indianapolis about 15 miles.
Or... gimme $4000 and take the motor and the Durango RT and do whatever you want... my 15 year old doesn't want it... and that was the main reason for it. Makes me no difference, I just want to break even on the Durango (which was driving fine until the crack happened and I parked it earlier this year)
10:1 hyper pistons
Rings
Clevites (all)
Double roller chain
Melling HV oil pump
ARP hardware
