Can someone tell me where I can find a correct speedometer cable grommet for my 64 Valiant? Neither from DTM is correct. Mine has a 1 1/4" hole in the firewall.
Doesn't give an od spec. If it's 1 1/4 it'll work. Thanks I'll have to give um a call.
Thanks, Jim! Looks like 32-0422-20 will fit the bill. I just wonder if that 1/4 ID will stretch to go over the nut. I might have to get a few. lolGood luck! Best bet is Steel Rubber. Scroll down to grommets. Let us know the correct one. I found the grommet for the AC line through the radiator support here.
https://d163axztg8am2h.cloudfront.net/static/doc/c0/57/fff0e82c46bedb3c7cba7ce871c5.pdf
Yeah, but dang, that just defeats the whole purpose. lolProbably have to slit it. Did on the AC line
I'll get several and try them. That's what I'll do if they split trying to go on.Dab of 3M weatherstrip adhesive and like new.
