340 stroker 422
About 3300 without overdrive and 2500 with overdrive.
I have 3200 converter for this thing.
Unless the road is very flat, at 2500 in OD you’ll have a bugger of a time keeping it out of detonation. Any little change in load will get it into tip in detonation.
You’ll have to be very careful.
At this point in time I'd cleanup the chamber and use a 0.050 head gasket and send it.
Plan was to make it a good driver…
Is that head gasket really going to do much? It’s like 11.8:1 with quench vs 11.5:1 without quench…
Then you missed on the compression ratio. You have to make compromises somewhere.
I‘s work on getting the compression down to 11:1 if you want to run that gearing.
What does a 4.10 gear look like for cruise RPM?
there's still quench at 0.050, it's the limit. Don't you think there's something to be gained by working the chamber?
Piston is not at zero deck.
Was going to be a bit deeper in but block was very bad and needed a lot of decking.
Ok, so how are you figuring your compression ratio? If you don’t do a down fill you are relying on numbers then piston manufacture gave, and those aren’t always right.
You need to do a down fill and do the math and see exactly where you are.
There is no option to run 4.10 in this, it’s already crazy over invested project ;-)
I’ll work on the chambers and cc them to see where it takes me I guess.
I should have one chamber ready tomorrow.
Fact is that I need 70cc chamber to be at 11:1 which is unrealistic I guess.
70 is possible with that head. 5cc’s out of that head is do-able.
The shape is the important part now.
I like the direction this is going in. Everything is pointing towards a good direction. Ratbastard is on target. Been there done this myself. No 2 cents to add in.
Any pointers? Chamber photos?
A FWIW cam card I’m running at the previously posted 11-1- 360 engine. I think your combo is going to work as discussed.
I run it with 1.6 rockers.
Change pistons or machine a dish in them.
You need to find about 12-14cc's, not easy to do.
Rotating assembly is already balanced as is. The only thing I can touch is the heads at this point and play with gasket thickness.
If you machined the pistons, the change in weight would likely do nothing to negatively effect the balance.
Read up on overbalance/underbalance and most engines run just fine in a range of 48-52% of bobweight. 50% being the typical bullseye. Say you had a 1900 bobweight, an acceptable range on that is 1862 to 1938
You are taking about 16 grams out of the bobweight with a 12 cc relief in the top on your piston.
Miszny:
[1] Leave the heads alone. Run it like it is. If you look at other aftermarket parallel valve heads [ Chebby, BBM, Pontiac, Ferd Windsor, etc ], they all vary slightly in the combustion chamber design....but all run well.
[2] I have had 8.5:1 engines detonate on 98 fuel, but my 9.9:1 engine doesn't detonate on 91 fuel. You have to run it to see......
[3] I agree with installing the cam straight up on 108 ICL because of the cam duration & 3.9 gearing.
[4] Did the E heads come with beehive springs?
Miszny:
Heads were bought bare, they have new valves, guides, springs seals and locks. Springs to match the small hydraulic roller cam which will be used with solid roller lifters.
So do I need to retard the cam 6 degrees now? Straight up it was 102.5 icl, I retarded it 2 degrees to be at 104.5
I just realized these are 65cc heads not 63cc by looking at part number of the castings.
