Never degreed a cam before. Can I do it with cam, lifters and new TC setup with no heads installed? Heads arent ready to install yet.
Thanks
Steve
Thanks
Steve
easiest way to do it with a head off.
I believe you'll just need to rig a piston "stop".
I'm. 030" proud of deck so I will need to cobble shims.I used an old alternator bracket fastened between 2 head bolts with another bolt in the middle to use as the stop. Ugly but functional.
Hey Bro....I can mail you 2 lifters and an extra indicator if you want......I've got plentyThanks guys, great info. I may splurge on a 2nd indicator. I don't have any old lifters to use unfortunately.
Appreciate it!![]()
For the lifter business, if you have 2 good used ones, (flat tappet) disassemble them internally and join them together, contact surface away from each other. Use as the dial contact point.
Hey Bro....I can mail you 2 lifters and an extra indicator if you want......I've got plenty![]()
.030 proud?Thanks Wayne, good idea.I'm. 030" proud of deck so I will need to cobble shims.
.030 proud?
That's a lot
I don’t know what cylinder head you are using but if they are open chambers then that .030 out of the deck is FAR a better than .000 deck.
Yes, using X heads open chamber. Pistons are 2332P.030. I'm doing a DIY port job on them. I was going to get a few Killer Carbides, but shipping kills it unfortunately.
