Rapid Robert
1963 dodge dart. 360. one of the tie rod ends is barely contacting the tbar. (inner one on drivers side). Going back together with new tie rod ends/used sleeves. if it comes to this & it is looking like it will, how can I bend the pitman arm to lower the outer end of it down a bit? I'm assuming a torch is a no no. thank you for your time. RR
