[WANTED] 2 Fender Bolts for 1969 Dodge Dart GTS
Lord Sparky
Carlsbad, California
Looking for 2 original fender bolts for 1969 Dodge Dart GTS as seen in attached photo. The bolt head is 1/2 inch, not sure about the thread size. Already have the threaded clips they screw into.
I actually just noticed these were missing. I assume they were the same size as the other ones in the photo that go along the sides.
I have a bunch. They may have a different markings on the head. What is on yours?
Just for refrence...
Confirmed 67 Dart.
Washer 0.857 dia x 0.105 thick
Bolt od 0.300
Tip of bolt to underside of washer 0.867
Head thickness 0.200
Depth of head inset 0.072
18 threads per inch
All washers are the same size
Different markings but these are fender washers.
Al, those are some lovely bolts, but maybe I'll hold off until I can find some similar ones. Classic Industries has the whole set with what looks like the same stamping on top but they want $80 for it. Thank you for looking. You are a great member!
