2-Wire Packard 56 Terminals
mopowers
West Sacramento, CA
Does anyone have a source or part number for the Packard 56 terminals that take two 16ga wires? Or is twisting the two wires together and using a larger terminal the only option?
What he said
Also be sure to get a propper double terminal crimper.
Oh, I missed the putting two wires into one terminal. brain fog... LOL
JMO, twist them together, use a 12ga terminal, then hit the tip of the wires with some solder to lock in place.
@mopowers
American Auto Wire
@mopowers
Thanks Rob. That's actually what the gentleman at Electrical Depot recommended. Not sure it's worth buying a special wider open barrel crimp tool for either. Plus I can source the 12ga 56's locally if needed.
