RudeDawg, if you happen to come across this thread I would appreciate some information on tire/fenderwell clearances on your 68 with those Centerlines that you sold back in January. They sure looked nice on your car. Mine is a 67 Fastback in MM1 Turbine Bronze Metallic and I think Centerlines would look good on it as well. I was specifically looking at the rear tire clearance from the outer fender edge and how much clearance you had regarding springs as well with the backset you mentioned. Tried to message you but may be a privacy setting that wouldn't allow it.
Thanks
Thanks
