Another 360 question (or two)
Once you get sealer on the studs for the water jackets, what’s the best way to tighten? I’m thinking hand tight is out of the question…
if you don't have a stud installer, just double nut it and run 'em in. they don't go in crazy tight, so just a short ratchet or wrench is more than enough to get there.
ETA: FSM has 20 ft/lb on the stud with the nut at 15
