65 here, and I wish I could loose this mfgut...Pretty sure I'm older than most of you guys at age 66. I just look young. Kkkkkkk or maybe it's the younger women keeping me young.kkkkkkkk![]()
I have five years on you Mitch ! My wife is one year younger than me , maybe I should get a younger one ... Naw !Pretty sure I'm older than most of you guys at age 66. I just look young. Kkkkkkk or maybe it's the younger women keeping me young.kkkkkkkk![]()
Valve stem seal. The rattling pcv valve is clue to me....easier to fix then rings....fingers crossedSquirt a little oil in the cylinder and check again. If it stays low probably the valve . If it goes up you are sealing the rings , should go up.
Why not? I traded in my last wife for a newer model. The last one is 65 now , And it was her choice to divorce. This one is 38....I have five years on you Mitch ! My wife is one year younger than me , maybe I should get a younger one ... Naw !
Grr.. running motorhome 440 with trans for $650 near me... i sooo shoulda went big block![]()
I always make the wrong choice.. that 440 would make more power for $650 than the 5k i will have in this small block... shoulda gave up on keeping the pushbutton, it's been a pain in the ***Where's that 62 Valiant 4dr that I saw for 5K? It soooo needs that 440![]()
SACRELIGE!shoulda gave up on keeping the pushbutton
SACRELIGE!
Fight the 3-pedal mind control!!!!
Jobs sure go a lot better when you have the tools!! I LOVE your shop.Well, I got it out of there. The clutch is still in it. Might at least change the clutch today, but I'll wait until tomorrow to put the transmission back in it. I ain't on nobody's time clock. Kkkkkkkkkkkk
Hah! You know what I am thinking!SACRELIGE!
That’s kind of what happened to me.Grr.. running motorhome 440 with trans for $650 near me... i sooo shoulda went big block![]()
That's a real nice one, FrankSo i need to fix up my kubota, needs a better seat. I have a better seat. But mounts are damaged. Would have to take it apart to weld it. Thinkin pop rivets or something. Wife comes home and hands me this.early birthday present.
Ok that’s some swanky right there! She did good!So i need to fix up my kubota, needs a better seat. I have a better seat. But mounts are damaged. Would have to take it apart to weld it. Thinkin pop rivets or something. Wife comes home and hands me this.early birthday present.
Mancini has them $22.99 .got 1 LCA apart... getting the pin out was 10x harder than the sleeve. but no biggy.. I assume all of the plate kits for LCA are pretty much the same or does someone make better?
hmm will look again, found the page but didn't have anything to order/price.. thanksMancini has them $22.99 .
Wife of the year materialSo i need to fix up my kubota, needs a better seat. I have a better seat. But mounts are damaged. Would have to take it apart to weld it. Thinkin pop rivets or something. Wife comes home and hands me this.early birthday present.
