Map63Vette
As the thread title suggests, I'm looking for some feedback on what people might be using for traction and launch control on their setups. I know Goody had a thread a while back showing the differences on a Cuda 3G swap, but curious if anyone else has played with it at all. I'm mostly just looking for some ideas of what kind of rpm to set for launch control and potential timing reduction curves for traction control. I wired in a potentiometer on my clutch pedal over the weekend so I could tune where the launch control releases, but I'm not sure what sort of rpm makes sense to set it at. I'm guessing it will probably vary pretty widely with engine and tire setups, but figured I'd ask anyway and see what people were having luck with. I tried it out at 3500 on a backroad with my ET Street tires and lit them up fairly well, but I realize it's also not a prepped racing surface. Didn't know if it even made sense to try to launch it that hard or not with my fairly mild build. Another setting I wasn't sure about was the soft limit retard value. It talks about timing reduction, but doesn't really give any advice on common settings. Guessing maybe this is more useful for turbo setups to provide something like anti-lag or building boost for launch, but also curious if anyone has played with different values on an NA engine.
Along those lines, I'm still not sure my traction control is actually working. Need to try to get some better logs one of these days, but when lighting the tires up during my launch test I never noticed any kind of timing cut to bring things back into line. Guessing maybe one of my trigger values is just too high, but it's been hard to reliably cause slip with my street slicks on. That being said, I'd be curious to see what people are using for the reactions settings. Currently running slip% trigger at 10%, but otherwise just have the stock reactions to try to limit power. Only timing retard at the moment, ignition cut and fuel changes are all zeroed out.
