Nice!! Wanna sell someday, let me know
It’s actually interesting. They use electronic controlled valves to reduce the oil pressure to the hydraulic lifters on 4 cylinders within milliseconds. While also shutting off fuel and spark.I like simple and not a good mechanic so less going on under the hood the better.
ANy time. It's a dandy one.Nice!! Wanna sell someday, let me know
So happy to see our friends up in Minnesota got some badly needed rain yesterday, 2 and a half inches I believe @FISHYPETE
Let me get thru this last attorney payment this month and I’ll follow upANy time. It's a dandy one.
I would stick the filler in first then epoxy over that just make sure the bare metal is clean.Hey, @Fred Scigliano ... should I shoot that epoxy primer first then use the filler on those weld patches?
Was wondering how they did that Thanks Chris.It’s actually interesting. They use electronic controlled valves to reduce the oil pressure to the hydraulic lifters on 4 cylinders within milliseconds. While also shutting off fuel and spark.
And also best to let the epoxy sit before painting over it for I can't remember but think 24 hours. Directions on the can I'd fallow that.I would stick the filler in first then epoxy over that just make sure the bare metal is clean.
Also just so you know there is a window of letting bare metal set without resanding it and that's about 24 hours more or less depending on the humidity.
You can paint your base clear right over the epoxy if you want and if it looks good after the epoxy is on and your happy with it, I would read the directions but 24 to 48 hours and don't have to sand the epoxy just put your color right over it.
Hard trying to help without being there.
I wonder if she has a zip code on her navel? How else would she get mail in her box?Ok you guys wanting for the delivery...there might be a delay with a package check.
I'm still lurking! Actually in Canada right now. Taking a couple weeks to just travel and see new stuff. I'll be back to normal in a week or so. Back to being lewd and offensive!!!Where has he been anyhow? @Ben Drinkin
Hey, while you’re there, can you show the Canadians how Americans put out wildfires…I'm still lurking! Actually in Canada right now. Taking a couple weeks to just travel and see new stuff. I'll be back to normal in a week or so. Back to being lewd and offensive!!!
Interesting.
Sounds like you have it under control. I'm not sure how much you knew but obviously a lot.I wiped it down with rust inhibitor because I knew it would be a while before I got back to it.
Well she's definitely going to get a package deliveredOk you guys wanting for the delivery...there might be a delay with a package check.
Well she's definitely going to get a package delivered![]()
