Sixpack_Sid
Anybody try this floor shifter?
I guess it's enough to be called a shifter. I guess. lolThats not much of a shifter, but it looks simple enough, should work just fine I would think .
I wonder what it has for gates and detents?Thats not much of a shifter, but it looks simple enough, should work just fine I would think .
Just a simple groove and then the cable adjustment to make them match up, little spooky to me because they need to be in a position to stop at for say second gear , if not, the shifter will take the transmission out.. he needs to watch some videos on it and get it right.. detent would be kick down rod or cable.. I believe Mike.I wonder what it has for gates and detents?
Someone needs to copy the Slap Stick. What a great shifter.Just a simple groove and then the cable adjustment to make them match up, little spooky to me because they need to be in a position to stop at for say second gear , if not, the shifter will take the transmission out.. he needs to watch some videos on it and get it right.. detent would be kick down rod or cable.. I believe Mike.
Yep, a dandy thats for sure, a perfect match to all our 727 and 904 transmissionsSomeone needs to copy the Slap Stick. What a great shifter.
It's essentially a ratchet shifter. But I agree, someone should copy it right on the money as far as operation.Someone needs to copy the Slap Stick. What a great shifter.
Just send that in a personal message. ThanksNot sure what type you are interested in, but I have this one laying around....
[FOR SALE] - B&M Quicksilver Shifter
(Delete if needed, not sure I can post that here?)
that would be ideal, but then everybody would either: ***** about the price point, piss and moan that it's not quality and doesn't work *exactly* the same as the one they had 40 years ago, or grumble about the fact that their roached out OEM is better and should be worth more.It's essentially a ratchet shifter. But I agree, someone should copy it right on the money as far as operation.
