Lets see those stick shift Magnum cars!
How many stick shift magnum cars are on FABO
  • This many 5.9's
    Votes: 9 90.0%
  • This many 5.2's
    Votes: 1 10.0%
  • Total voters
    10
skep419
5.9 Magnum 4 speed afficionado
Minesoooota
I'm curious how many are on here and could use some motivational pictures.
I’m on the fence with my 69 Dart.
Just pulled my slant 6 and am getting ready to drop in the 5.2 magnum.
Not sure if I’m going 4 speed yet. Just worried about getting the correct pivot on the clutch pedal.
What do you do for a stock engine, 5.9 flywheel?
Since it’s a 5.2 / 318,
To my understanding, I can use the stock flywheel from a 318 since it’s an externally balanced engine like the LA 318
Not sure on the 5.9 to be honest. That’s one of the main reasons I went with the 5.2, simplicity of swap
Internally balanced, yes, it’ll work!
Well thanks to @skep419 !!!!! Now we know.
Thanks my friend!
:thankyou: Wooooo hooo! Magnum weight ordered.
Nothe " 5.2" is NOT external balance. Neither was the LA 318. The 360, both LA and magnum were but different amounts between them
I just bought a complete American power train tremec T56 magnum xl kit for an LS from a friend for a song and I am seriously considering putting it behind a 5.9 magnum
I want to see someone keep the Magnum EFI and swap a 4 speed. Parts are out there and I know of one person long ago that made it happen, but seems like everything else is carb'ed.
Crank sensor is the issue. Gotta sandwich the flexplate and machine a stock flywheel or simulate the crank signal somehow. Or run the system on a Holley and use the dual sync.
Exactly.
There is one company that at least used to make a 130T flywheel with the notches but I have yet see anyone ever do it. I saw one post about someone buying it, and then later selling it. And the one guy that has done it took a 143T flywheel and turned it down to fir the 130T ring gear. He is the only one I know of to use the Magnum EFI on a 4 speed.
I built crank pulley setup that I hoped would duplicate the signal since my LA couldn't run the above flywheel without a bunch of work. But I've changed directions so who knows if it would actually have even worked.
Edit - I forgot about the guy on YT that sandwiched the flywheel. So I guess there I 2 guys that have done it. That guy completely slipped my mind.
4:07 would that work?
I think this is what it would take to use the holley.
Exactly.
Where is that pulley now?
So a trigger wheel type deal. I’ve thought about calling in a favor to a machinist friend and having him cut slots in the hub of the crank pulley. Seems like some math could figure out size and spacing relative to the flexplate.
