pomonamissel
for high c/r motors , try e85 it's oc rating is much higher and its less costly . you may have to rejet your carb for it
May have to reject carb? Yea like buy a whole new carb that flows 33% more fuel. E85 is corn based ethanol, alcohol. You most definitely will need more fuel. And a lot of it.for high c/r motors , try e85 it's oc rating is much higher and its less costly . you may have to rejet your carb for it
Yes, the engine is firing, but the load on the engine is not there like it is while accelerating. With the throttle blades closed, there is very little fuel being fed into the cylinders.I can take a video.
For the "Vehicles don't ping decelerating", why is that? The engine is still firing while decelerating, it's just doing so at a lower RPM. And if the detonation is now occurring at a lower RPM after retarding the timing, I don't see how it's out of the question.
Now I could very well be wrong, and I am not using experience to justify my thoughts, just logic.
Your mechanic recommended?? I recommend trading him in for a different model. He should first be looking at the plugs to see if it is one cylinder or all.Tbh, I have no idea how lower octane will help reduce it
It is what my mechanic recommended
Ping is a description of detonation or preignition. Both can sound like a can of marbles. Detonation and preignition are two separate conditions.I can take a video.
Possible you pumped a low octane fuel by mistake, as in wrong fuel at station.Actually no, that's why I think it might be the lack of fuel additive, it slowly got worse (I'm assuming as i refilled the tank, the additive got more and more diluted).
It has stopped getting worse, and it's much, much better after I retarded the distributor, although it isn't completely gone.
Vaporization is likely not the issue.What if running a lower octane fuel actually increases vaporization?
3 tanks???Possible you pumped a low octane fuel by mistake, as in wrong fuel at station.
Re:compression cycles: testing compression in diesels an injector is removed, the fuel bypassed and the engine started.If you want to get an idea of how EFFECTIVE cylinder pressure is related to throttle position, just do a compression test with the throttle closed, and record the pressure on each stroke.
You might get a number like 90 psi on the first shot, then
120 , then then 140,150,155 and so on, but eventually, given enough compression cycles, you will get to the same number that you would get with the throttle at WOT. The difference is that on a good engine, at WOT, it might take half as many cycles, and the First shot will be significantly higher..
The same thing happens while you are driving, at various throttle settings and various rpms.
Knowing the specifications of the engine, it is possible to back calculate the Effective Compression Ratio from the cylinder pressure. When you do that, you will find out that;
your Effective compression ratio at IDLE might be just 5or6 to 1.
And at 2000 rpm , with the throttle closed and under decel, it might be a tad higher.
And at WOT at rpm of Peak Torque, you could be pushing 11:1 or more Effective, depending on the cam and combo.
And at Part Throttle, you can vary the Effective CR anywhere in between, just by adjusting the throttle position.
In fact, you could even hold the throttle at a steady position in a fixed transmission gear; and the Effective Compression could change everywhere throughout the rpm range as engine efficiency wanders around.
Why is this important?
Well, pressure makes heat, and heat makes power, so the more heat your engine can generate, the more power it can build ....................... right up until the design can no longer deal with the heat. When that happens she can get into preignition and/or detonation, which leads to destruction of parts. So the goal of the Builder and the Tuner, is to not let that happen, by keeping the chamber temperature under control. To do that, we have a number of tools in our toolkit that we can use;
1) anti-detonant,
2) reduced Effective cylinder pressure
3) retarded ignition timing
4) reduced load
5) a reduced cooling system temperature
As others have said, detonation under closed throttle deceleration is as good as impossible...................... because that eliminates all five of the things that can lead to detonation. Yes, it can, still happen, but it's gonna take a hot glowing spot in the chamber to initiate an uncontrolled and inappropriately timed, point of ignition
Is there a point of contention here to what I said, or are we on the same page?Re:compression cycles: testing compression in diesels an injector is removed, the fuel bypassed and the engine started.
In gas engines all plugs are removed. I used 5 compression strokes to get the compression reading. You will get to a point that the reading no longer climbs, but generally 5 is close enough for a realistic reading.
You will not ever get a compression reading of cylinder pressure during combustion, peak cylinder pressure, without special test equipement. Under load the cylinder pressure could be 1,500PSI.
If it doesn't vaporize it doesn't burn does it? Does that make it lean by any chance?Vaporization is likely not the issue.
