Theory about 727 and wheels up launch
RockinRobin
Corsicana, Tx
Had an issue at the track today. 1st pass went wheels up like always but when I shifted to 2nd it acted like it was in neutral and hit the rev limiter. I shifted to 3rd, everything fine and got off the track.
Went through all 3 gears on the way to the trailer and all was fine. At the trailer, dipstick had no fluid on it. It was 1 1/2 quarts low! Drained some when I got home, no leaks, no odor or bad color, no metal particles on the magnet.
Filled to correct level and all seems fine. SO HERE IS MY THEORY:
Since it was 1 1/2 quarts low (stupid me for not checking) I'm wondering if you are doing a significant wheels up, if the fluid can slosh away from the pickup when the wheels come down.
(727 torquflite, reverse manual valve body, lots of high HP internals and pressure cranked up)
With some of the terrain I see the local Jeep crowd maneuver I’m amazed they stay engaged.
Deep pan??
Deep pan pickup??
Some people have theories on NOT using the deep pickup, but I don't agree with them.
When my trans has gone low and I turn a corner it sucks air and freewheels
Makes sense. I've seen some custom fabricated filter extensions that bias the filter to rear of pan.
Maybe try a baffle? I found one in an old racing trans, thought it was a neat idea.
Manual transmissions don't have that issue.
