- Joined
- Jul 17, 2023
- Messages
- 1,208
- Reaction score
- 2,432
- Location
- Somewhere north of Minne-a-no-place
Ok, good info.
From what I can find, any of these can cause that alarm:
* Gas is shut-off.
* PCB not sending 24 VAC to gas valve.
* Bad gas valve.
The pressure switch is before the HSI in the Sequence of Operation, so if that didn't make, your HSI wouldn't light-up. So you're good there.
I had to download the Kenmore manual to find this info (it's not in the Keeprite Manuals, for some stupid reason), but you can find it here:
See pages 50-52.
So back to Square One. Is the gas "on", and if so, is the gas valve receiving 24 VAC on the MV terminal 17 seconds after the HSI warms-up?
And just an FYI, when the gas valve does energize, you'll hear it, if you're listening for it. You can also feel it, but it's light.
* Gas is shut-off.
* Bad gas valve.
See pages 50-52.
