valve adj. on engine while on engine stand before. start up
Get a Mopar Performance Valve Lash Adjustment Chart. Once you have oil pressure (priming w/o running) adjust the rockers until you can just spin the pushrods with your fingers. This will put you very close the final adjustment.
Since '66 still used solid lifters from the factory, I'll assume you've converted to hydraulics; and since you're asking about setting lash (actually, preload with hydraulics) I'll assume you retained the adjustable solid lifter rocker arms. I'll also assume you got custom pushrods of the correct length (solid and hydraulic lifters use different length).
Prime the engine, and then adjust the rockers so there is just zero clearance. Then give the adjusters another 1/4 turn.
That's a whole heap of assumin. lol
You can read this.
How to Set Valve Lash
This is what I do.
Starting at Number 1 cylinder, rotate the engine until the exhaust rocker just starts to open the exhaust valve. Set the valve lash on the intake rocker at this time. Continue rotating the assembly and stop when the intake rocker starts returning from full lift. Now the lash on the exhaust rocker can now be set. Continue this procedure for the remaining cylinders following the engine’s firing order.
If setting preload for Hydraulic lifters remove up and down play on pushrod then add ¼ to ½ turn of preload. Some people say tighten until you it gets hard to turn the pushrod then set preload I don’t agree with this method as the lifter may not be pumped up. JMO. If the motor was just running then yes this works.
This method works on almost any flat tappet engine
All suggestions will work, I would have done this before the intake was installed, no oil pressure. Also, find the travel of the tappet with his set up and then get in the middle. The decal worked for me until I measured the timing tape around my balancer, an indicated balancer would be okay. So I do the rocker arm method now.
I'm curious, everything here says 1/4 to 1/2 turn preload. The machine shop set mine at 1/2 turn (340 TA heads and rockers), but both the DC Engine book and the FSM say 1&1/2 turns... Can anybody shed light on this?
Need this printed poster sized and laminated so I can hang it on the wall.... lol
Well, it works good for mild to moderate camshafts, but the bigger they get, the more skewed that chart is.
Yeah, 1 to 1.5 turns down is too tight, IMO. I never go by the number of turns. I throw that out the window. I manually MEASURE preload.
Get out or upload the Factory Service Manual and follow the procedure.
Service Manuals – MyMopar
The FSM doesn't cover hydraulic lifter preload when using solid lifter adjustable rockers. The '70 TA book is as close as you'll get in that regard. Otherwise the FSMs won't mention it since the factory hydraulics were non-adjustable.
The Hemi instructions in the FSM are based on hydraulic lifters and adjustable ductile iron rocker arms and the instructions call for 1&1/2 turns in. The Direct Connection Engine book has instructions based on using 273 factory adjustable rockers on any LA small block and it calls for the same thing, but everybody I know that uses an adjustable hydraulic system does 1/2 turn with good results. I'm just wondering why the discrepancy...
Once you start throwing aftermarket parts into the mix, that's the best way to do it. Considerations like lifter manufacturer, use of aluminum heads (which can "grow" when hot), etc. can affect the amount of preload you want to dial in.
For example, Rhoads publishes a good set of guidelines for initial set-up that illustrate the procedure and reasoning that applies to most lifter brands.
