[WANTED] Single piston caliper bolts
Janke1010
Oklahoma
Hey guys, working on a 71 duster with 73 k member and suspension components, I picked up a new set of calipers from oriellys that are just single piston, look identical to the oems. But I lost the bolts apparently, so looking for a full set of bolts if anyone has any. I think its the bolts and pins?
That's funny I just seen a post he had on brakes and took a shot on messaging him lol
DORMAN HW5516 or RAYBESTOS H5516A
available from rockauto to amazon to local parts stores.
pretty much any a, f/m/j & r(?) body as well as vans & pickups. basically any sliding caliper from 73~96-ish
[/QUOTE
I have all the hardware for the caliper itself, I just need the jolts to bolt it to the spindle
those kits come with the bolts that hold the clips down that contain the caliper, if that's what you're talking about. i don't remember the size-- maybe 1/4-20 but they do have a captive washer that i believe is conical.
at about 12 bucks from that's pretty cheap for the correct hardware. but you could just hit up a hardware store and grab some grade 5's and knock it together with a little loctite.
