How to make your G3 alternator a 1 wire connection
racerjoe
Louisiana
I'm sure most people that have gotten themselves into a G3 swap without using the factory ECM end up in a situation of having to make the alternator work. I know the old school voltage regulator is supposed to work, but what about the guys who want a clean engine bay? There is certainly an aftermarket resource for a one wire battery connection alternator, but they are pricey. I have a solution to convert your G3 alternator to an internally excited, one wire (battery cable) hook up that costs $50 and about 20 minutes of your time.
Here's how you do it. This is an 06 alternator. Once you remove the plastic back cover, this is what you will see. The brown cover over the shaft contains the brushes for the armature. The two pin connector is basically just a means for the factory voltage regulator to connect to these brushes.
Below the brush holder is removed.
Now the terminal block is removed.
I forgot to take a picture of mine before it was installed, but this is what will be installed. It's a self excite voltage regulator for the Delphi voltage regulators. The part number is IN6324SE. You can find a few places online that sell them. Mine came from a vendor on ebay. Make sure they show "SE" in the part number because there is a IN6324 without the SE. That won't work. SE= self excite.
Note its missing a screw terminal where the original connected to the brushes. That's because this regulator requires one brush to be grounded. Also not the bent tab. That's the stator connection. It's how the VR knows when to turn on. It "reads" the frequency. Lucky for us, the diode plate already has that connection. It just wasn't being used.
So here's how you install this VR. You will need to drill and tap small hole where the red dot is located. Install the old terminal and mark the hole. I believe all the screws are M4, but I live in America and I use SAE screws...lol. Actually I had some 8-32s so that was good enough.
You will also need to make a small spacer to make up the difference of the old terminal used to be. I used a small piece of copper tubing for the spacer. The key is you want a good ground here. I ended up using a 1/2" long screw.
Here is installed. See that small hole in the brush holder? That's so you can stick something in there to hold the brushes back while you slide it over the end of the shaft. I just used a paperclip. Don't force it on or you will break the brushes.
Remember the stator connection I mentioned. This is it. Just solder that connection. The stud off the diode plate is copper and mine was dirty from not being used and being bare copper. Clean that off before you assemble everything so you know you will have a good solder joint.
So here I have the case of the alternator connected to battery negative and the positive on the output stud of the alternator. What you see is just battery voltage.
I spun it up with a drill and the result is obvious. It puts a noticeable load on the drill and lets off when I slow the drill down below it's operable range.
Clearly I don't have any miles on this, but it will be going on my car. I'll order a spare VR and I'll be set to convert a store replacement whenever I need to. This could be done without drilling and tapping if you just ran a ground wire to the brush holder.
The plastic back cover will need to be modified slightly for this to fit.
I hope this helps someone!
I believe I just made it a sticky for everyone, I will see if I did it right.
I did it, my very first and I am glad to help this great sight.
I wanted to provide an update on this alternator modification since I now have about 600ish miles on my G3 swap. The voltage regulatory is working perfectly. Just last week I drove to a cruise night 70 miles from home. This was the longest drive at night since getting the car back on the road. With the headlights on and the AC blowing on high it worked just as it should. That's pretty much the largest amp draw the alternator will ever see and its perfectly fine.
@racerjoe This is great info, and thank you for this. I have this in my alternator, and going to test soon. Question - truly one wire (nothing connected to the black 2 pin)?
If you’ve done everything I’ve outlined here, there is no connection required on the two pin. Just connect the charge post to your battery.
I'll also mention that you need to make sure the case of the alternator has a good ground that is common with B-. Modern electronics require many more grounds that are connected to the battery than these cars did back when they were built. My motto for EFI system is, if you think you have enough grounds, add more.
Looks like I need to do this to my alternator. I have one of those Quick Start systems and I'm not impressed with the voltage which might be why I'm having some weird issues under wot on a hard pull. Thanks for sharing this!
80% positive. It’s the same part numbers from an “SE” part from this eBay seller Self-Exciting ALTERNATOR VOLTAGE REGULATOR DENSO 126600-3060 IN6324SE | eBay
I haven’t tested it yet to confirm. But I’ll update when I do.
This is disappointing... I swapped in the regulator, it self excites and charges but I get the same 13.8 volts I got before with the Rapid Start. I have a feeling there's an issue with the alternator itself, I should be getting better voltage. I have grounds all over the place, maybe I need more?....
Any updates on function or issues? I am going to order this regulator and do the conversion in the next week!
I've put many more miles on the car along with plenty of autocross runs. Sat in traffic with AC on with 95 degree ambient at Cruisin the Coast in October. Hasn't missed a beat. I don't even think about it anymore to be honest.
Great to hear! Thanks for putting this thread together.
What is wrong with 13.8?
In the quest for this, have you discovered or know differences between the later Magnum/ hemi/ etc alternators from say, 95ish to present? A member here seems to think his had some electronics in his (later) alternator which complicated things. I have not kept up on this later stuff. Probably the latest I have looked at was 2001--02 or so, and they were simply an isolated field alternator.
I only did this investigative work on this alternator, which is on an 06 engine. I'd image many of them are the same in this era.
I am going to do the conversion with a 2013 challenger alternator. I will let you know if it works!
Sounds good. I looked on Rock Auto and they appear look the same but have different part numbers. I do see the later ones have a higher amperage option, 180 and 220A. Looks like those have the clutch on the pulley. The 160 looks the same as the 2006 alternator. All you can do is try.
The belt spacing changed on the '11+ VVT motors too. Block was the same between an '09-10 and '11+ VVT motor so alternator bolts to the same location but pulley would be further out on the later motors. That would explain the change in P/N.
I took some time to research which rear cover would work with this voltage regulator if you don't want to modify the factory part. You will need to search the internet for the rear plastic cover for a 2004-2011 Cadillac CTS. I found one for under $20. I haven't purchased it yet, but it appears to be the correct one considering that is the make and model that uses this style voltage regulator. It may be easy to find one at a pick a part junkyard too.
