- Joined
- Mar 17, 2018
- Messages
- 13,592
- Reaction score
- 31,016
Agreed!Shoutout to @ RustyRatRod
For all the help rebuilding my steering column.
Class Act he is.
Class Act he is.
I have to make a list of things, like don't forget to take something out of the freezer for dinner, Don't forget to take dinner out of the oven before I fall asleep.I know...I hate lists
Perfection right there!
Thats what smoke alarms are for silly. Make a reminder to change the battery out!I have to make a list of things, like don't forget to take something out of the freezer for dinner, Don't forget to take dinner out of the oven before I fall asleep.![]()
66 runs good. Should be up to it....Should be fun for sure!
I had a smoke alarm start churping a couple days ago. The date on the battery was 7/2019. They last a lot longer than 6 months. Energizer'sThats what smoke alarms are for silly. Make a reminder to change the battery out!
I'm staying pretty current on my smoke alarms Ray, they get tested every time I make dinner.Thats what smoke alarms are for silly. Make a reminder to change the battery out!
That’s a big ole Red X for me. Nothing about that looks good.#1 reason to join the air guard
Herding redi-mix drivers and asphalt delivery drivers for 20sum years, hardly a day went by when I didn't open it at least onceAnd easier than a thomas guide... (if anyone remembers them)
Herding redi-mix drivers and asphalt delivery drivers for 20sum years, hardly a day went by when I didn't open it at least once.
Agree.face almost looks photo shoped on. A few skin tags on the neck area also.That’s a big ole Red X for me. Nothing about that looks good.
0k Karl.Well I got the fiberglass done and waiting for it to harden. American made and hand laid.![]()
Time for an adult beverage it sounds like.Was a day. And not a good one. Brake booster was leaking into cab. When i tweaked pedal rod i shifted a seal. Think i have that sorted out. Key was rough in lock cylinder and column covers werent fitting right. Full size column parts are same as s10, thats a bonus. So fixed that.
I put a non clutch flex fan on, discovered today it turns wrong way.
I dont have an electric fan that fits. Ordered a new one.
Once i established cooling, a/c works but clutch is dragging and noisy. Need a puller and shims. Fml…
Was that on your list?Just so you all know I found my list
Sorry Frank sounds like my luck the last few days.Was a day. And not a good one. Brake booster was leaking into cab. When i tweaked pedal rod i shifted a seal. Think i have that sorted out. Key was rough in lock cylinder and column covers werent fitting right. Full size column parts are same as s10, thats a bonus. So fixed that.
