Proportioning valve question for disc brake conversion
Yes it is a dual reservoir, saw two videos of someone just hooking it into the rear brake line in between the master and the stock combination valve. So i think im gonna do it that way.
If you have drum brakes all around, it's a distribution block, not a combination valve. Also, unless the line coming from the master cylinder goes STRAIGHT to the rear brakes and does not go into the distribution block, I don't believe you can just put it in the line going TO the distribution block. That would control more than "just" the rear brakes, I believe. It must be in the rear line alone in order to control pressure to the rear. I believe that's correct. If I am mistaken, I will count on my comrades to correct me. Regardless, I would still put it in the rear line, since that's all I would want to control. ......but then as I mentioned earlier, I would use all the factory stuff like I did on mine. Makes it much easier. Good luck with it.
So… I did the front disc swap on my 68 recently. I’d planned an adjustable valve but having second thoughts.
Is the factory prop valve a direct replacement with the distribution valve ?
New direction
You have it backwards
Actually neither one of you are right or wrong, as, poorly stated
The fact is whether or not you need proportioning depends on weight bias, tires, sizes of brakes whether drum or disc, and so on. A vehicle, light in the rear, with large rear tires and lots of traction, might just need a prop valve with all drum brakes. Or, with front disc/ rear drum, and the same situation, "may not."
And the same may be true (may or may not need) with ANY system, all drum, disk / drum, or all disk.
We are of course also throwing vehicle mods in the mix, meaning mismatched brake components.
IN FACT I AM FIGHTING THAT RIGHT NOW on my 04 GMC. I bypassed the ABS because the brakes sucked and I was having trouble getting them to do much. After converting to hydroboost, and a few other things, I now have a Willwood prop valve to the rear disk, and IT IS NOT ENOUGH. For some reason the rear disks lock up much easier than they should.
