Found Three Miller Special Tools in Storage!
dibbons
La Paz, B.C.S., Mexico
I have '65 ABodies and a 1972 BBody. Purchased these special tools years ago. Does anyong know the part numbers so I can look 'em up and see the applications for 'em? Thank you.
The bottom one is a ball joint socket. No idea what the top one is unless it's a burnishing tool for the distributor bushing.
Measure the socket and we can tell what ball joints it fits. It will be an odd measurement down to the 32 of an inch.
I only have a dial caliper that measures mm: 45.5mm converts to about 1.79 inches. The socket has eight sides but is kind of square in the middle (the measurement I made is across the square portion).
Most Miller tools from the 60's and 70's have a number stamped on them.
The number usually starts with C- or SP-.
