Oil filter adapter leak
remytherat
Los Angeles
360 magnum. Oil filter adapter off of a ‘73 318. All surfaces cleaned well. New gasket kit. Copper washer. Torqued to 50 ft lbs.
Oil dripping from between bolt head and filter adapter.
What to do?
Thanks Rob, yep the adapters are different. I never knew until I installed one on the 340, leaked like my ring after spicy wing night. That's when I fired up the googling machine and discovered I had a magnum plate. Put an LA plate in and no issues.
[FOR SALE] - Magnum oil filter plate.
What to do?
I don't think the LA and Magnum adapters are interchangeable. @4spdragtop knows about this, I think.
Oh boy, yes they are different it seems.
To be clear, I need a 90 degree filter to clear my exhaust. Below is the leak. Is there any way I can make the 90 degree work? Shim the cork gasket?
Same filter for both applications, right? Anneal the copper washer. Hang it on a steel wire, heat with a small, hand torch, then quench in water or oil. A ferrous metal with carbon typically would harden from quenching but nonferrous is generally softer than slower, air cooling.
The adapter I used on magnum based 408 leaked as well. Tightened the crap out of it stopped the leak
