360 4bbl 833 4 speed manual transmission 8 3/4 3.23 sure grip 489 case. Big bolt pattern front disc brakes, 10x 2 1/2 rear shoes. 340 exhaust manifolds and stock dual exhaust. Engine is stuck with a Wiend Stealth intake and 650 Edelbrock avs II carb. Not an original Formula S car but dressed as one. Originally a white car with black interior, color changed years ago. Runs, drives and stops well. Everything in working order including a factory AM/FM radio. Inland shifter handle mounted to a Hurst shifter mechanism from Brewers Performance. I've owned this car for nearly 20 years. Located in Warminster Pa near Philadelphia PA. $32,500.
