Project Cheap & Nasty Updated With Back Story
I have the same problem, I will build and engine, and let it sit for years before installing it in something.
Or build a different engine for the same car.
Nasty.
Got cheap & nasty's freeze plugs in today. The brass looks cool against the green. I sealed them with Permatex #2. Just to give yall somethin to argue over.
Just tell me you aren't taking the cheap part so far as to skip the Plastigauge. :p
Going to port any oil or water passages while working on the block?
Cheap & nasty's cylinder head. It looks a lot worse than it is. I'm not using the 66 casting. I don't even know what year this one is, but it's a revised chamber head. But the reason I'm using it is because The guides and seats are pretty nice. I knurled the guides a while back. I know that's divisive, because there are two camps regarding that. Some say it's ok to knurl and some say it's a short lived, easy fix. The Comp 901 spring is what I plan on running. So I figure with such light spring pressure and a very mild cam it will last a while. Besides, remember cheap & nasty? I do plan on getting it milled just enough to clean it up. All I plan on doing is lapping the valves in. I'm even going to use some blue Viton umbrella seals. Cheap & nasty.
Cheap & Nasty's head all wire brushed, primed and painted. More green. lol The valves still have wide margins and they sit up proud like they're supposed to.
You don't need a machine shop to clean up that head surface. Use the concrete floor or use the side of a 8-12" grinding wheel. A liberal dose of wd40 will help displace the swarf.
It's not right by today's standards. Or yesterday's for that matter. Back when all we had was rent money and book money (school) we fixed plenty of engines using farmer tricks of days gone by.
I thought I would try something like that, but if I posted it on here, I'm sure I'd get made fun of. I'll check it with a straight edge first.
Ok, so I thought I was gonna have to buy some stuff. Turns out I have a good set of retainers, a set of brand new valve keepers, and what appears to be a good set of valve springs. Do any of you know what green stripe slant 6 valve springs are? I'm only going up to "about" .450 lift. I'm not opposed to buying some valve springs. I'd get the Comp 901, of course, but chit a mighty. Have yall seen how high they are now? Dangit man!
Slanty springs are weak, just going to '68 & up 273/318 springs will bump the open #'s 30-40. You should have a bucket full of 'em....lol...
