New Product Coming Soon
Dana67Dart
The parts you don't add don't cause you no trouble
Northern Colorado
I'm working on making the foam gaskets that go between and around the gauges and lights inside the 67-71 Dart gauge cluster.
The foam will have peel and stick adhesive on one side, black in color with a density and thickness to match the OEM parts.
NOTE: The kit will come with one extra gasket (not shown) for the 70-71 Brake Warning Light as it is a slightly different shape than the 67-69
I would be interested in making kits for other years and bodies but will need to barrow parts, so if you are interested, PM me with what you need and have.
I would expect to have finished parts in a month or two.
AND....
They will be designed and "MADE in the USA"!
