[SOLD] Disk/drum brake OEM proportioning valve
physixx
Edison, NJ
I have for sale a used OEM brake proportioning vale for the disk/drum brake applications so if you do the conversion, this is what’s needed. The numbers stamped on the body of the valve are 3258924 and 3423936. From what I found, it’s used on the 67-76 A-body cars, 67-72 B-body cars and the 70-72 E-body cars. I would like to get $45.00 for it plus the shipping.
I just found out that this prop valve fits the 73 and up A-body cars.
Thanks Dana67Dart!
Ken
Edison, NJ
FYI. This is 73 Up on A Bodies, 72 Down uses a different valve not incorporated into the distribution block
