[Found!] NOS upper Aarm right side 67-72 a body
Does it have to have the '67-72 2071456 part number stenciled on it, or, will the '60-66 2071452 number work for you? I've interchanged them, and can't see any difference. Maybe you know?
I have two left ones both have 2071457 on them . Can you send me a picture
A 2071456 IS a passenger side....sounds like you already have two of them. Generally Mopar part numbers were.....even numbers RH or passenger side, and odd number were LH/driver's side.
In the late 1960's Chrysler superseded the 2071452 and 2071453 to 2071456 and 2071457.
Even numbers are right side and odd numbers are left side.
Look at Chrysler parts catalog on mymopar to confirm right and left part numbers.
The flat area where the upper control arm bumper hits is toward the front of the car. This will differentiate left and right arms. Early A body will only have the small upper ball joint
