1969 Dart 2 door rear side window glass install
nothingbutdarts
Bailey, Co.
Glass was pulled long ago, I screwed the bolts in when I pulled the glass. The bolt has a big washer and there was also a round plastic piece on the bolt, is there supposed to be 2 round plastic pieces one on each side of the glass? Or if just one plastic piece, does the plastic piece go on the other side from where the bolt & washer go thru the window?
Thanks!
There shouldn't be an metal against glass anywhere. All mounting areas use a soft gasket of some sort.....some rubber, some plastic, some more of a cardboard material depending on year, type of fastener/bracket, and location of the glass.
^ ^ ^ ^ ^ ^ Photos will have to come when there is daylight.
Dana, I looked for your Dart at the cruise today, didn't see it. I was hoping to visit with you.
Seems a plastic milk container will do the trick.
There is a fiber washer on each side of the glass and a rubber sleeve over the bolt. I think the rubber sleeve is for anti rattle purposes(fills gap between glass and bolt). I used some anti seize on the bolts. Had one that was corroded and broke during removal.
You can get the bolt dimensions and go to McMaster Carr or Fastenall and find a workable solution.
I was thinking that, I’m just super keen to keep everything oem, but if repro is stupid expensive, then yeah probably do that.
Do you know what companies sell them new?
