SIZE DOES MATTER
Oldmanmopar
Going left turning right
Danielsville Pa. 18038
When it comes to labor rates. 360 rod verses a big Cat . Piston pin is larger then the 360 rod journal
Can I get a "Hell, Yeah!"? I couldn't agree more, Mike!
When I watch those videos I'm reminded of when I first started out in Commercial HVAC, as I told my fellow Tech School classmates, "If I can't walk inside of it, I don't want to work on it." And thus my first job was working for Mammoth, who made large, custom penthouse systems. Loved those 250 ton and larger units!
Wow!
Hell Ya. Love it.
When I was young, I had the privilege of rebuilding a Blockair air compressor at a steam plant. I was an apprentice. They had a crane set up over it for pulling the heads off. The compressor looked like a big block hence the name. The pistons which there was 2 were about 12-14" in diameter. Can't find any pics online but was impressive. Probably built in the 40's or 50's.We used to change rings, bearings, and valves every other year. It worked continuously.
