Matts440
More pics
That looks great. What weight springs do you have on the front end?
I'll look tomorrow for some number, should write them down lol they came with the car when I bought it from Mad DartThat looks great. What weight springs do you have on the front end?
Nope can go lock to lock without hittingThese look great. No issue with front tires hitting when turned in?
Numbers I found are QA1 10 450, so 450lb springs in the front and 12-130 in the rearThat looks great. What weight springs do you have on the front end?
Thank you. Those are strong springs.Numbers I found are QA1 10 450, so 450lb springs in the front and 12-130 in the rear
I'm shocked they are compressed that much. I run a 450lb on my HDK and they aren't compressed nearly that much. However, mine are 12" springs. It almost looks like they would get into coil bind on a big bump.Numbers I found are QA1 10 450, so 450lb springs in the front and 12-130 in the rear
I avoid big bumps lol. Not sure, might be with all the twins and all the piping. Unless I read the number wrong was on the back side and using a mirror, hopefully not a 10-150.I'm shocked they are compressed that much. I run a 450lb on my HDK and they aren't compressed nearly that much. However, mine are 12" springs. It almost looks like they would get into coil bind on a big bump.
Spray it with N2O. It’ll loosen the converter up.Thanks! 15-16 psi
A looser converter is definitely needed to get my 60ft down. Not much I can do when it won’t leave over 2500 rpm! Calculator shows zero percent slip up top though so at least I can be sure the trans isn’t slipping
The turbo would spool up quick too! I ran nitrous on my GLH… it was so much funSpray it with N2O. It’ll loosen the converter up.
I am very happy that didn’t happen!Wow, good catch before it took everything else out.
Believe me I WANTED to setup my car that way, but I also wanted high quality injectors. $2500 for ID1700’s is a tough pill to swallow. I can also honestly say I did not realize I would need so much fuel system. I used fuel injector calculators that say what I have should support 1000hp, but that’s clearly not the case.No one believes me when I say, “when you think you have enough fuel flow for the horsepower you want, DOUBLE IT!”
That’s good for injectors, pumps, lines, anything really regarding fuel flow.
I almost certainly would not go from e80 to e60 if you’re aiming for more boost. I’d rather up the base presssure more than loose the octane.Believe me I WANTED to setup my car that way, but I also wanted high quality injectors. $2500 for ID1700’s is a tough pill to swallow. I can also honestly say I did not realize I would need so much fuel system. I used fuel injector calculators that say what I have should support 1000hp, but that’s clearly not the case.
Right now I think my best bet is to dilute from e80 down to e60 to see how much room that gives me. I’m currently aiming for 25+ psi boost so that may still not be enough fuel. After that I can also increase my fuel base pressure to get 1400ish cc from these same injectors(I ran ID injectors at 90psi base on my wrx), but I’m not sure how far my pumps will take me. I can add a 3rd 380lph pump very easily(already have a spare), but at that point I’m running a total of 4 fuel pumps pulling 50ish amps. I think the battery can handle that for 9 seconds but I’m not sure. Bosch 220’s may be the easiest fix. We’ll see
